alltracman78":36yp106z said:
Damn wiseasses
haha.. ok ok..
this is provided your engine has healthy compression and your stock turbo is free of play..
like silverarrow said..
basic boltons:
3in exhaust from the dp back.. (aussie dp/midpipe/catback)
boost controller - so you can raise the boost
fuel cut defenser - so you can raise boost without hitting fuel cut..
boost gauge, so you can keep track of where your boost is at..
straight intake with airfilter..
fuel pump relay hack - constant voltage to pump..
and i believe theres a mod to have the pump constantly running for the intercooler isnt there?
if you can swing it.. a front mount is always nice.. hehe
aside from this, i'd also recommend doing a basic tune-up if you already havent done so.. plugs (1 step colder), wires, cap, rotor, oil change, coolant flush..
now that youve got some decent power.. i'd also try to lighten things up a bit.. easiest thing to do would be to remove the spare tire.. now if you want to get more serious.. well theres plenty more to do, but they require a little more "commitment".. hehe
