Added my fire extinguisher last night. I would have preferred it parallel to the passengers seat, but all those lines that run underneath it plus its a little too bulky for there. My tunnel was all clean so some self tappers worked okay. I practiced a couple of times getting to it - like 'oh fuck I'm on fire' , popping the bonnet and runnin around the front. You can never be too careful
(spray between the cracked bonnet, or down the vents, don't open it up!) .You can see the old stain at the bottom of the footwell. It will not budge. I may eventually rip the carpet out and steam clean it, because i still haven't found molded carpets for '185s.
Went for a cruise down Myponga Reservoir, across the dam and down to Normanville, hit the bakery then the beach, then back again. It is an awesome road. It pretty much covers every corner type on a road with some short straights, blind corners, cliff faces, horizon corners ( you see nothing but the end of the road and sky, like those swimming pools, so you brake a bit earlier and heavier
) , hairpins and switchbacks. I might have to come with a name for it - There's a Tail of the Dragon road posted on these forums, something like that.
