jonnyboygt4
I was just curious....from what i read on previous posts on the forum regarding this topic...id like to do it on a budget....
what id like to know is....do i have to use the same negative post as whats under the hood? or can i just set it up to ground? another is for the positive cable....can i use say a power cable from a subwoofer (0 gauge)? and just attach it to the current positive cable under the hood?
also would i need to run a on/off switch? i know ill have to make some sort of battery bracket to hold it down...ive got that part figured out....
your help is always appreciated...
