Just removed the lever, little more pull when driving that I've been complaining about for years.
Pix show passenger side....
I won't be held liable if you do what i did, i pulled two units apart to fix. Safety belts are no joke!
I revived the white lever from the seat belt assembly that gives you less trenton when the door is closed. Both sides...I still jump cause the noise is not there.
-jr
So in on the trail, but everytime someone new sits in the car the are scared they just broken something. I noticed it only happening on my passengers side on my red one, but both on my black car.
The noise I'm speaking of is like the worlds biggest velcro being pulled apart towards the rear of the door. It will not happen again until car is driven 5+ mins... I've lubed the rubber seal around the door, but tonight I believe the door panel is sticking to the rear interior panel. Been raining the past few days so I haven't looked into the issue yet. I'm not lost, just know I've been bugged, seeing if other people have solved it.
If no answer tonight, I'll have one tomorrow for everyone else.
-jr
I did search, and no return. Thanks
-jr
-jr
