Hey guys, I'm trying to get the AC out of my RC, I've already got the pump off the block and the two lines that were attached to it removed, as well as the AC fan. The front bumper is now off and I've realised that the intercooler sits in front of the AC, with another small cooler bolted to the right side of it (I was originally under the impression that the AC was at the very front).
My question is as follows: what is the easiest way to remove the AC at this point? can it be done without dumping the intercooler water, the engine coolant and whatever else is running through the cooler in front of everything? what the heck do I remove, as it looks like everything is blocked in on all sides.
