Engine management showed up today as well! Going to make some progress this weekend routing some of the leads. Still waiting upon shrink wrap, plugs and the insulation for the harness.
This is Megasquirt's new MS3-Pro ECU with an 8' flying lead. Its rated for a wide range of temperatures compared to some of the other offerings on the market.
Here is a complete list of the MS3-Pro's features:
Hardware features:
Freescale MC9S12X 16 bit, 50 MHz asymmetrical dual core processor
10 saturated injector drivers
8 logic level ignition outputs
3 high current (5 amp) general purpose outputs - 2 can be reconfigured as additional injector drivers
3 medium current (3 amp), high frequency general purpose outputs
All unused injector and ignition outputs can be used as SPARE outputs. This ECU has a LOT of I/O!
1 stepper H-bridge driver
Camshaft and crankshaft differential inputs - supports VR, Hall effect, and optical input
12 volt tach output
Fuel pump output
8 analog inputs (5 dedicated sensor inputs, 3 spare/general purpose)
4 spare digital on/off inputs
3 spare digital frequency inputs
2 knock sensor inputs
RS232, USB 2.0, and CAN communication
Onboard 8 gigabyte SD card for internal data logging
Internal ECU temperature sensor
Real time clock
Temperature range: -30 to +80 degrees C (-40 to +85 without battery for real time clock)
Software features:
Supports speed density, alpha-N, or MAF based fuel and spark tables
1 microsecond injector pulse width resolution
Tables for nonlinear injector behavior at small pulse widths
Allows blending multiple load types, including specialized mode for independent throttle bodies
Supports a wide variety of OEM cam and crank position sensors
Individual cylinder trim tables for fuel and ignition
Accelerator pump or model based acceleration enrichment
Closed or open loop idle speed control
Closed or open loop boost control with gear or speed based tuning options
On/off or closed loop continuously variable valve timing control - supports up to 4 channels
On/off or progressive nitrous control
Traction control
Rally anti-lag
Rotary support - can run up to 4 rotor engines with separate leading and trailing spark tables
Staged injection
Table switching
16 x 16 fuel and spark tables - can be reconfigured to function as 30 x 16 or 16 x 30 by switching tables based on RPM or load
2 or 3 step rev limiter with no-lift shifting
Wideband AFR target tables
Flex fuel sensor input
Allows repurposing injector or ignition outputs as general purpose outputs, or high current outputs as injector drivers for 12 cylinder sequential applications
Real time barometric correction
A/C and cooling fan control with idle compensation
Safety shutdown based on AFR or EGT input
Sequential shift cut and air shifter control
6 General purpose on/off or PWM inputs
Hardware features:
12 volt tach output
Fuel pump output
Real time clock
Software features:
Traction control
Rally anti-lag
Staged injection
Table switching
