fuel pump assembly
quieter
hi everyone! i was wondering if fuel pump assemblies were interchangeable between st184s and st185s, mine is rotten and needs to be changed, im trying to install my aeromotive stealth 340lph fuel pump. its pretty much impossible to find an alltrac here so i was wondering if that bracket is interchangeable. i tried comparing it to the BGB but im still not sure and cant find the model number. thanks!
So does somebuddy know the partnumber for the module assembly or whatever its called.. the guy that holds the fuel pump. Got two pipes comin out n a power n ground wire.. lol i cant find nothing...
Thanx in advance
warracer
If you can't find one, I have an alltrac complete fuel pump assembly, its a bit rusty (outside) but some patience could do the trick, the thing is, I wanted to keep it as a spare... But I could sell it if you're really puzzled :)
