How much power can the OEM LSD handle? bolting up the transmission is definitely going to be fun, its not exactly a direct bolt on. The front side mount will work and the top transmission mount will work, the rear mount is definitely will have to be fabbed. Clutch is fine, passenger axle is fine, the driver axle will be frankinstiened. lol. As progress continues I will update. The shift linkage will be custom. I am taking mine from my E-350 modifying it to fit the E153 and will be on the right side of the transmission as I need. I have to drill one hole in it for a bracket and cut a grove for the external c clip. I will post pictures later.
