So I am trying to figure out some caster dimensions. I am measuring the Tein HA hats. When turned it seems the maximum it pushes towards the back of the car is about 22mm. So Who has used a tein plate? I am curious how much 22mm of movement equates to caster. It also equals about 12mm of camber if I measured this all right.
Looking at the slots on the T3 plates it looks like it only allows maybe 7mm of movement back from 0. They predict 1-1.5 caster adjustment. Looking at the others who turned, their plates look like we might have a similar range, and if they can get 3 degrees at full back here is my guess. Lets say 22mm equals 3 degrees of caster than 7mm or so will only be around 1 degree of caster adjustment.
Anyone have an estimate of how many mm yours is moved back? Or at least the length of adjustment of the camber slot and width.
