GT4CS: The Quest for 400awhp!
Re: GT4CS: The Quest for 400awhp!
Postby 88gt4DE » Wed Jun 11, 2014 11:48 am
Car looks amazing ... 185 like yours is the only thing I would part with my 165 for. I would bet if the fuel filter was clogged you'd have driveability issues too not just a stall ... but if its old I'D change it anyways ...
2000 Toyota Tundra SR5 - 165K - Thanks 97JZA80
2008 Toyota Avalon - 110K - DD - Work Runner
2007 Toyota Rav4 - 145K - Wifey DD
Postby psipwrd » Sat Jun 14, 2014 10:37 am
The fuel filter and starter were both changed yesterday and the problem still exist. I started another thread for it but the video is here.
https://www.youtube.com/watch?v=taVQkGL ... e=youtu.be
Stalls as soon as the fan kicks on.
1992 Toyota Celica GT-Four CS (#4025)
ImageEuro-Spec ST185 CS in Las Vegas
...still working on it...
psipwrd
Postby Tecker185 » Sat Jun 14, 2014 4:14 pm
Have you tried jumping the fuel pump in the diag box? The fuel pump resistor does funny things them it goes bad.
93 ST185 2grfe swap in progress
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
95 Tacoma 2uz swap manual Dually
17 4runner TRD Off Road
Tecker185
Postby psipwrd » Sat Jun 14, 2014 8:11 pm
I found and fixed a broken wire coming from the chargecooler and it idled w/o stalling for 45 mins. Test drive will be tomorrow or in a few months.
psipwrd
Postby Meurz » Tue Jun 17, 2014 9:41 pm
Also check and rip out any dodgy alarm/immobiliser wiring. Caused mine to stall randomly. :shoots:
Turbocelica.nl
Meurz
Postby psipwrd » Sat Jul 12, 2014 9:32 pm
I found a little box connected to the ECU, Italian tuner company. I had it removed during the install. Didn't find anything else. Going to focus on the other big items for the project and post pics when they come in...
psipwrd
Postby psipwrd » Tue Aug 19, 2014 10:09 am
BBK is in! Looks Amazing! I meant to get red calipers and black hats but it will still stop the same!
psipwrd
Postby 760gt4 » Mon Sep 01, 2014 12:42 am
Everything is coming along real nice! Good thing you're staying in Europe and able to keep the car with you. Continue to keep us updated please, this is a fun thread so far.
760gt4
Postby psipwrd » Wed Sep 03, 2014 7:20 pm
Thanks! I try to keep it entertaining, just too much time between updates. More to come within the next 6 weeks!
psipwrd
Postby psipwrd » Thu Oct 09, 2014 10:19 pm
Tomorrow is the last duty day in Germany, Sunday I'll be reunited with my car...er umm, my wife! I'll post pics of the new goodies I picked up along the way!
psipwrd
Postby psipwrd » Wed Oct 22, 2014 5:08 pm
I changed the fuel pump Saturday and was still having no-crank problems. I did the starter relay mod today and she fired right up. :D
I was able to drive around the neighborhood for 20-30 mins, turn off and crank back up a few times. Tomorrow I'll button her up, add gas, and see how it goes...
psipwrd
Postby psipwrd » Tue Nov 25, 2014 9:46 am
SHE LIVES!!! I finally figured out my problems: two blown capacitors on the ecu, loose pin at ecu, bad spark plug wire and bad coil. Changed them all along with the igniter and plugged in a straight berk patch cable. What's tricky is that I got continuity on the back of the oem ecu harness, but nothing at the berk harness. So I wiggled the oem harness until i got continuity, reached over and cranked and she fired right up! Idles fine, but misfires with gas. I'll do a permanent repair of the pin and see if that solves the misfiring.
Footnotes: No NE signal completely kept it from getting spark.
- ignition signals were good to back of oem ecu harness but pins weren't making contact. Would still be looking if I didn't have the patch harness.
psipwrd
Postby psipwrd » Thu Dec 04, 2014 7:01 am
I passed inspection, got the car re-registered and am good to take the car to Germany where the project will live on.
I saw a lot of threads about catch cans, installed one while the car was down and ran into some issues i didn't have before installing it. The fittings on the can are smaller than that on the valve cover causing the pressure to build up enough to create a leak somewhere around the distributor. It looks like the pressure builds up enough for the valve cover seal to leak and burst oil out on the distributor and charcoal canister. After cleaning it up, there is no sign of a leak until the car is driven again. I'll be removing the catch can immediately and see if the problem goes away.
psipwrd
Postby CMS-GT4 » Thu Dec 04, 2014 4:30 pm
There is an interesting article somewhere on here about the PVC and the pressures, it may be helpful in figuring out a setup that works. I never heard of anyone have any troubles before though.
92 st185 (205 swap) | 03 350Z Track (sold) | 13 Pilot | 17 Mazda3 | 12 Vroom Vroom
linktr.ee/ColdironWorks | www.coldironworks.com | http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=19891
Postby underscore » Thu Dec 04, 2014 4:53 pm
What kind of catch can is it? It might be clogged/blocked.
