Quick question: ST205 WTA IC into ST185...
AvivB
Does the WTA IC of the ST205 fits on the ST185?
I know about the extra pipes but I wonder about main air inlet, outlet and brackets...
MoTT
I know it can fit (I know someone who installed it) but it needs some home made fixations :p
I plan to do it too in 2015. I'll begin to look for informations soon. I'll let you know if you're interested !
AvivB
I need to replace mine and it is much easier to get the 205' ones...
Do you know what modifications needed?
MoTT
It's juste the fixings. It is thicker than the original one and the Carlos Sainz WTA so you have to move it a few centimer on the right if I remember correctly. If you don't, you won't be able to close your hood properly.
athousandleaves
You need to bend the inlet pipe to the right a few cm and if you're staying with the 2nd gen throttle body you'll need a silicon reducer I think 2.75" to 2.25"
Someone did post a how to on the boards a while back.
