MWP's wannabe Tarmac Rally 5S-GTE ST185 (racing!)
Re: MWP's wannabe Tarmac Rally 5S-GTE ST185 (racing!)
Postby MWP » Mon Sep 28, 2015 6:31 pm
We have a country wide motorsport governing body called CAMS that sets all the rules for our events (they are basically a motorsport specific insurance company).
No one has any idea how decisions are made at CAMS. Some things they are harsh on, some things they are easy on.
Most of it is political :twisted:
[color=Blue]Daily:
Toyota RAV4 ACA23R
Race-Car: Toyota GT4 ST185 5S-GTE
MWP
Postby CSAlltrac » Mon Sep 28, 2015 7:10 pm
Car sounds great, nice and healthy. That hill climb looks like it gives the suspension a beating too.
Postby MWP » Fri Oct 02, 2015 9:22 am
Yeah everything seems to be great with the car at the moment.
Ive done that hillclimb a few times in my old car at around the 40sec mark.
Its amazing how much of a difference going a bit quicker makes to how the bumps/undulations feel.
On the last run after the first corner before the "wall" the car got enough air to spin up the tyres.
Another better view of the start: https://www.youtube.com/watch?v=n0CNgW16GIo
[color=Blue]Daily:
Toyota RAV4 ACA23R
MWP
Postby CSAlltrac » Thu Oct 15, 2015 5:14 pm
Ive been wondering, where do you have your FF Sensor placed. Meaning what line did you splice into. Currently working on getting one setup for my next build. Ive read that guys locate them in different spots so Im curious as to whats correct. Pre fuel rail or post rail in the return line.
Postby MWP » Thu Oct 15, 2015 7:24 pm
CSAlltrac wrote:Ive been wondering, where do you have your FF Sensor placed. Meaning what line did you splice into. Currently working on getting one setup for my next build. Ive read that guys locate them in different spots so Im curious as to whats correct. Pre fuel rail or post rail in the return line.
FF sensor?
[color=Blue]Daily:
Toyota RAV4 ACA23R
MWP
Postby CSAlltrac » Fri Oct 16, 2015 12:39 am
Flex Fuel......sorry
Postby MWP » Fri Oct 16, 2015 12:47 am
CSAlltrac wrote:Flex Fuel......sorry
Ah :)
Mine is on the return after the FPR.
[color=Blue]Daily:
Toyota RAV4 ACA23R
MWP
Postby aus jd 2703 » Fri Oct 16, 2015 12:50 am
Flex sensors can go any where, I have heard of a few people running them in the pressure lines, this helps create a stable reading as it always has fuel and no air, where as the return line is empty on start up and is usually aerated by the regulator to a degree. putting it at the bottom of a 180" bend in the return line would likely help fix a lot of issues.
aus jd 2703
Postby MWP » Tue Dec 08, 2015 12:27 pm
At the Willunga Hillclimb event i competed in a week ago :D
Video: https://www.youtube.com/watch?v=DNqdvFOQDco
[color=Blue]Daily:
Toyota RAV4 ACA23R
MWP
Postby CSAlltrac » Tue Jan 12, 2016 2:45 pm
Im curious if you run your upper timing cover.
Postby MWP » Tue Jan 12, 2016 4:27 pm
I dont run either.
I cant run both as the caldina cover doesnt match up with the lower 5S cover.
Running just the lower 5S cover would turn it into a scoop and trap more than it would help to keep things out.
[color=Blue]Daily:
Toyota RAV4 ACA23R
MWP
Postby MWP » Sat Feb 13, 2016 11:18 am
So as mentioned in another thread, ive now solidly mounted my diff in the rear subframe.
Ive also filled the subframe with a 2 pack expanding high-density foam. Hopefully itll help with the noise a little.
While the sub frame was out, i thought it would be a good idea to drop the fuel tank and install the Walbro 400lph pump ive had sitting in a box for a few months.
So who said E85 corrodes fuel tanks?
Its had E85 in it for 5yrs now... looks like new :)
Walbro 255lph vs new 400lph. Almost physically the same size.
Ready to go back in.
Could do with a good steam clean :P
[color=Blue]Daily:
Toyota RAV4 ACA23R
MWP
Postby MWP » Sun Nov 26, 2017 3:01 am
Small update... :rofl:
New Bilstein 46mm UMS, Prius front hub, new 205 caliper brackets, shorter tie rods, and DIY lower control arms.
It was a HUUUUUGE job. Months of planning, and two weeks (~6hrs/day) worth of doing.
I did all the design, CAD, and steel fab work. Bilstein blank tops were machined & prepped by a local guy.
Was finished midnight on thursday, test driven for 1hr fri morning, then on a trailer for the 6hr drive to compete in a Hillclimb on Sat morning :twisted:
[color=Blue]Daily:
Toyota RAV4 ACA23R
MWP
Postby MWP » Sun Nov 26, 2017 3:06 am
Then went and raced it at the hillclimb.
I hadn't driven the car in 9 months, and with the new suspension too i went easy(ish) on it.
https://www.youtube.com/watch?v=bq9M4qVwm9I
The car did 16 runs over the two days.
New suspension worked great :D
Missed the last couple of runs of the hillclimb though due to this:
Spare rear diff is in the car now though.
Aiming to enter another hillclimb in 2 weeks time.
[color=Blue]Daily:
Toyota RAV4 ACA23R
MWP
Postby ZeroDrift » Sun Nov 26, 2017 3:17 am
Good work on the suspension! That is certainly a great deal of work to engineer and spec something together like that.
Out of curiosity- do those prius hubs have the same mounting points/dimensions for the brakes?
Sent from my LGLS992 using Tapatalk
Users browsing this forum: Google [Bot] and 0 guests
