I cant seem to find a part # for that thing anywhere. Mines cracked and hitting my serpentine belt. Need to get it replaced ASAP, any help greatly appreciated, picture is attached.
They don't. I checked. 3S-GTE MR2 had the alternator in a completely different spot. 3S-FE/GE Celicas and Camrys don't have the wires routed quite the same in that area.
Once you do find one, you may want to fabricate a bracket for the lower mounting bolt if you have an aftermarket downpipe. The stock downpipe has a stay with a bolt hole for the wire harness mounting bolt. On my car, this was loose and caused the issues with the alternator belt rubbing on the wire harness.
