lalojamesliz1
grip-addict":1vqhl3kb said:it IS possible to do the injector and fpr swap with the rail on the head, but it's not exactly easy. It'll definitely be easier to do the work if you pull the fuel rail out.
Witch Hunter should put new orings on your injectors, but if they don't, you can get them from primemr2 https://primemr2.com/collections/gen3-3 ... gen3-3sgte
I had a hard time finding gen 3 insulators (these go between the fuel rail and the head). Turns out, Supra insulators work on the gen 3 fuel rail / head and you can get them from the dealer: 23291-88480
Hope this fixes you up! good luck!
Thanks man, that's some great information
