ST185 Speedo/tach gauge faces
Looking for parts, ask around!
Postby amx » Sun Nov 20, 2022 11:24 pm
I have a ST185 gauge cluster with the gauge faces from a GT-S which are 10mph and 1k rpm short. This is probably a long shot, but does anyone know of a source for these? Or a printable high-res scan?
amx
Re: ST185 Speedo/tach gauge faces
Postby 93celicaconv » Wed Nov 30, 2022 12:09 pm
So just your gauge faces are incorrect? The speedometer & tachometer mechanisms behind the gauge faces are correct for an ST185?
93celicaconv
Images: 26
Postby amx » Fri Dec 02, 2022 1:36 am
Yes, long story short I have an original ST185 cluster with 160mph speedo/9k rpm tach, but missing the faces for the speedo and tach. I swapped them over from a GT-S cluster I had as a donor, but was hoping to find some replacement faces that are actually factory correct for the all-trac.
amx
Postby underscore » Sat Dec 03, 2022 5:43 pm
Skewer just posted pictures of these custom 7th gen gauge faces they made, they might be able to make you ST185 ones https://m.facebook.com/story/graphql_pe ... Njc1NTQ%3D
Return to Parts Wanted
