InitialD93
how is a 15.3 1/4 time at 92 MPH for a mildly modded ST185
FMIC
3" race pipe (no cats no mufflers)
straight intake
MBC at 12 psi
FMIC
straight intake
MBC at 12 psi
This is so LAME!!! :evil: hahahaha 8)InitialD93":36m73v60 said:how is a 15.3 1/4 time at 92 MPH for a mildly modded ST185
rm2932":1w1gq675 said:just to have sometyhing to compare to I ran 14.2 @92 mph with a 1.9 60 foot.
so your mph is high enough that your car should be mid 14's easy.
acylon":myqn2un3 said:Try launching at 5000rpm. Be sure to shift b4 you hit rev limit as you will lose time if you do. If you are running street tires use normal pressure, I have found that letting air out makes traction worse. Don't drive thru the water box. Don't shift B4 7000rpm in any gear.
Try all of these things and your time will improve.
Nothing crazy. GTS has more power to the wheels with the same motor, so at some point on the strip (when it has enough traction) it starts to accelerate faster.SeanGTS":bchruupd said:Its crazy to see an 10 MPH difference from the alltrac, to a swapped GTS.
