Post Your Setup!
Post Your Setup!
Postby RedCelicaTRD » Mon Aug 09, 2004 5:36 pm
Just like the title says! Post what suspension mods you've made and give them a review. Hopefully this will help people pick a decent set-up for their style and show people whats avalible. I'll start.
Mods: None :D
Review: I havn't driven my car in so long I can't remember how it feels.
Now my review sucks so I know you guys can do better!
Postby Gary » Mon Aug 09, 2004 5:43 pm
Wheels: OZ Rally 16x7 30mm offset
Tires: Yokohama AVS ES100 225/45/16
1 inch H&R Spacers in rear
Springs: Stock
Struts: Stock
There is no rubbing with or without the spacer.
Handling is much better than stock 15 inch setup.
93 ST185
Gary
Postby turbo4wd » Mon Aug 09, 2004 6:56 pm
Wheels: 5Zigen 5ZR Copse 17x7.5 43mm offset
Tires: Yokohama AVS ES100 225/40/17
1 inch Spacers in rear
Springs: Whiteline
Struts: Stock
Swaybar: Whiteline adjustable
Strutbar: Whiteline front and rear
The inside of the rear tires rub against the rear struts without the spacers.
The amount of roll has been dramatically reduced compared to stock..
The current setup understeers in slow to mid speed corners, while the rear end can be kicked out on higher speed turns..
Dan
Undercover Moderator
turbo4wd
Postby killer_siller » Mon Aug 09, 2004 8:38 pm
i love those rims! too bad it wouldn't look as good on my car (white on white).
looks awesome.
turbo4wd -
how much did the whiteline setup run you? do they make it for the 165?
you set it up to understeer in low / middle speed turns, how much and why?
killer_siller
Postby Griffin » Mon Aug 09, 2004 8:41 pm
Wheels: SSR Competition 17x7.5"
Tires: Yokohama A032R 235/40/17
Suspension: Tien SS Coilovers
Swaybar: stock
Strutbar: Jspeed front 3point
Brakes: Slotted stock rotors / SS Goodridge lines / Porterfield R4S pads
Alignment bt West End Alignment
Weight reduction: A/C removed, Sunroof Removed, Interior gutted, RC front bumper, wheels (13.2 lbs each)
The handling is just awsome - I have yet to find the limits of the car with the new setup.
The tires have excellent grip in both cornering and normal acceleration. They help at full pressure from a standing launch, even on tarmack (the clutch however did not) There is minimal body roll, and the ride is firm, but not too harsh. The tires sing a bit, but its only noticeable over the exhaust when decelerating. So far I can take a 90 degree right at 50 and the car just flat out turns. The steering does want to follow the road a bit with these tires, but its not too bad.
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby killer_siller » Tue Aug 10, 2004 1:13 am
:shock:
that is just f***ing awesome!
is it your daily driver?
got pics / commentary on the gutted interior (i know this isn't the post for that, but...)
killer_siller
Postby turbo4wd » Tue Aug 10, 2004 2:14 am
You know what, its been so long (2 years) that I forgot how much I paid for everything.. I got the works kit for the 185, and the springs.. My struts were brand new.. I have yet to install the rest of the bushing kit.. I'll do that once I take my car over to West End Alignment..
I didn't set up the car with understeer per se, its like that to begin with.. When I only had the rear adjustable swaybar on, the car was VERY neutral, and much easier to oversteer.. After I installed the front and rear strut tower bar it made it more understeer prone because the front became much more rigid
In my case I would have to stiffen up the rear more than it is now relative to the front end.. A set of Teins would help... :D
Suspension setup is tricky, because you want to find a good compromise between roll stiffness (sway/strut bars), dampening (springs/struts), as well as weight reduction/distribution to acheive total balance.
Some people can't bear a super stiff setup, while others love it.. I gravitate more towards the stiff end myself.. but again, there are compromises.. With a softer setup the limit of adhesion is easier to identify because its more progressive, whereas a stiffer setup although it may give a higher limit, can also a little more difficult to find because the difference between your tires gripping and going off is more abrupt..
Ah.. and to update.. heres a list of Whiteline stuff for the ST165.. but keep in mind that there is a HUGE delay on Whiteline stuff..
http://935motorsports.com/st165whitelinelist.htm
Dan
turbo4wd
Postby killer_siller » Tue Aug 10, 2004 11:25 am
i'm having visions of autocross victories
oh god, now i have to spend money that i don't have. i love you and i hate you. thanks
killer_siller
Postby Griffin » Tue Aug 10, 2004 3:35 pm
killer_siller wrote::shock:
Nope - its a weekend and occasional weekday only car.
I don't have any pics of the interior yet. Been waiting for the body shop to finish with it so I can clean it up and start stripping the sound deadening out to drop a bit more weight.
Dave Staba
Sealy, TX
Griffin
Postby InitialD93 » Wed Aug 11, 2004 4:38 am
Tires: 215/40/17 Yokohoma AVS ES100s
Rims: Tenzo R Mean-6 17"x7"
Struts and springs: JDM JIC SA-1 fully adjustable coilovers
Tranny: rebuilt tranny w/new syncros
Differential: rear clutch type LSD
Swaybars: stock
Strut tower: stock 3 point front
Alignment by Lee's Alignment(local)
everyday street driven, and soon to get into some autocross.
Future plans=H&R 35MM rear spacers, 4 or 8MM front spacers, Yokohama A032Rs or Yokohoma Parada Spec-2s mounted on lighter rims for autoX, front and rear sway bars, cusco under brace.
Dustin
1990 All Trac w/ RC bumper, converted to 93
^^^ Old project about to start a new life ^^^
InitialD93
Postby Rider » Wed Aug 11, 2004 6:01 am
Wheels:14"
Tires: Standard
Springs: Whiteline
Struts: KYB with insert conversion at rear
Swaybar: Whiteline
Strutbar: Standard
Bushes: Whiteline
Untested...until tomorrow, needs a wheel alignment and to be road legal...
1990 ST185
1996 Toyota Carib
New Zealand
Rider
Postby Zeus » Wed Aug 11, 2004 11:19 am
17x7 Konig GT-R Rims
235.40.17 Toyo T1s Tires
Whiteline Lowering Springs
Whiteline Rear Sway Bar
Whiteline Camber Bolts
Whiteline Bushings
Koni Yellow Shocks
Review: the spring shock combo I find are way too soft and i bottom out when the suspension is allready loaded and i go over a bump or something...
For the future... either at the very least some stiffer springs but ill probably want to get some coilovers as well as strut tower bars and maybe some under body and side bracing... I also really want to get a rear spacer and some 245's on some wider rims
Blake Brown
Zeus
Postby RIalltrac » Wed Aug 11, 2004 2:43 pm
Rims: 17x7 Konig Blatant's with H&R 20mm spacers on the rear rims
Tires: 225/45 Kumho Ecsta Supra 712's
Suspension: Whiteline Springs
Koni Yellow Shocks
Superpro Poly Bushings (Also filled my rear diff. bushing with Poly)
I like the setup its not over the top aggresive. My AT is daily driven. My only compaint to date is the tires, they just arent grippy enough, but they get the job done for now.
Chris - 90 ST185
RIalltrac
Images: 2
Postby silence » Thu Aug 19, 2004 2:31 pm
Tires/Rims: 16" 2000 celica GTS
Struts:KYB adjustables up front, New Toyota in the back
Springs: Ground Controll adjustable coilovers
Swaybars: stock
Suspension Techniques Polyurethane Bushings up front.
THe setup is nice. I like the adjustability of the Ground Controlls, with the kYB's. The Ride is relatively stiff, but nothing harsh. I have the struts set at 3. THe car will begin to understeer when going into a turn, untill you hit the throttle Id like to improve my setup with poly bushings in the rear, and a larger rear swaybar combined with a rear strut bar and some good grippy tires.
06 WRX, 90 Celica Alltrac & 88 BMW TURBO 325is
http://www.youtube.com/watch?v=Ei5P9LfLRdg
silence
Postby pog0 » Thu Aug 19, 2004 6:20 pm
Wheels: 16" 2000 Celica GTS
Tires: Bridgestone Potenza RE090 or something like that
Springs: TRD Japan
Swaybar: Whiteline Rear Adjustable
Waiting on: Rear strut bar, poly bushings all around.
Kevin Hall
92 Gray ST185 - Sold
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
