Attn: EPC people - I need a few part #s
Postby ___Scott___ » Thu Sep 28, 2006 12:57 am
My EPC went down with a hard drive crash about a year ago, and I haven't been able to get it working since. So, I need to ask someone with a working EPC for a few part numbers. All are for a 1st-gen 3S-GTE just in case it matters (like for the oil pump gasket.)
- Valve stem seals (both intake and exhaust)
- Intake gaskets (one on each side of the TVIS plate)
- exhaust gaskets (I thought I had a set but I can't find them)
- Oil pump "o-ring style" gasket (as seen below)
- Starter ring-gear, not the whole flywheel (as seen below)
- Dowel/tube thing that aligns the head to the block and holds the gasket in place while you torque the head down (as seen below)
Oil pump o-ring style gasket
Starter ring-gear
Dowel/tube
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby Gary ST165 » Thu Sep 28, 2006 10:20 am
PNC#15100B Part Number 15188-63010 RING, O (FOR OIL PUMP)
PNC#11155A Part Number 90253-10004 PIN, RING W/HEAD (dowel tube thing!)
PNC#13711A SEAL OR RING, O (for valve stem oil)
Part Number intake side 90913-02062
Part Number exhaust side 90913-02066
PNC#17173 GASKET, EXHAUST MANIFOLD TO HEAD Part Number 17173-88380
PNC#17177 GASKET, INTAKE MANIFOLD TO HEAD, NO.1 Part number 17177-88380
PNC#17179A GASKET, INTAKE MANIFOLD NO.2 Part number 17177-88380
PNC#13453 GEAR, FLYWHEEL RING Part Number 13452-74010 (SUBS) 1345-74011
regards
ST165 turbo 4WD
Gary ST165
Postby ___Scott___ » Fri Sep 29, 2006 3:31 am
Thanks Gary, I really appreciate the help.
Scott
SONY
___Scott___
Postby ___Scott___ » Sat Nov 18, 2006 3:22 am
Gary ST165 wrote:PNC#13453 GEAR, FLYWHEEL RING Part Number 13452-74010 (SUBS) 1345-74011
Minor correction, the SUBS number should be 13453-74011
Scott
SONY
___Scott___
