no spark
no spark
Postby zak062 » Fri May 17, 2013 5:01 pm
Hello gentleman. Its been a while since ive been on here. Long story short, I had to store my 165 for about 3 years. I took all the proper precautions when I did. Now she just does not want tovstart. I have no spark at all coming out ofvthe coil. I have power going to it. I just bought and replaced it with a denso toyota coil. My rotor, plugs, wires, and capv all have less than 100 miles on them. So why the hell is no power coming out of the coil. Thanks in advance.
03 Subaru wrx(DD) My first non-toyota
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
88 alltrac, blue (Project)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
[img]http://img263.imageshack.us/img263/3199/zac062copyto3.jpg[/img]
Finaly got an all-trac :)
zak062
Re: no spark
Postby GT4_DRED » Fri May 17, 2013 6:55 pm
If its a factory coil, make sure it's grounded to the chassis. I strapped mine to the strut brace once and it wouldn't fire, but did once I bolted it to the brace.
'00 SC300 - "Big Butt"
'88 ST165 - "Rahtid"
'88 ST165 - "Supah Cyat"
'88 ST165 - "Cornbeef"
'88 ST165 - "Redhead"
'91 MR2-T SMG
'92 MR2-T Nautical Blue
GT4_DRED
Re: no spark
Postby Awesome-Trac » Fri May 17, 2013 7:06 pm
Make sure to check the plug connected from the alternator bracket to the chassis, mine actually melted and never got a spark until it removed and properly replaced with a non plug type ground cable
•Daniel
Awesome-Trac
Re: no spark
Postby zak062 » Fri May 17, 2013 7:17 pm
I just ran a ground from the coil to the coil to firewall as suggested. Still no spark. Ill check the alternator plug.
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
Re: no spark
Postby zak062 » Fri May 17, 2013 11:02 pm
Update. I have proper grounding. I read through the bgb and after runing all the tests. It says to replace the igniter. Thats the final step. So does anyone have a igniter.
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
Re: no spark
Postby warracer » Sat May 18, 2013 12:32 am
before changing the igniter, check your rotor/cap? The car has been sitting for 3 years, it is possible that some moisture got stuck in the assembly and completely ruined the contacts, seen that before. So much resistance due to the corrosion, no fire whatsoever... And to simply diagnose an igniter, just crank the engine and if the tachometer moves, its fine. If it stays flat, change it
____________
JDM ST185H A-Spec:
-50 Trim CT26 -BC Racing coilover
-Yonaka FMIC -Swift Spring
-3'' SS exhaust -Poly bushing
warracer
Re: no spark
Postby zak062 » Sat May 18, 2013 12:36 am
Theres no power comming outvof the coil. And the tach is not moving.
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
Re: no spark
Postby zak062 » Wed Jul 03, 2013 12:19 am
Update. I bit the bullet and bought a new ignitor. Still no spark coming out of the coil and the tach still does not move. Any suggestions?
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
Re: no spark
Postby warracer » Wed Jul 03, 2013 1:20 am
try to check the continuity of the connections? you may have some kind of dead end in your ignition circuit somewhere, it can be a pain to diagnose though... The igniter trick worked out fine for me... :doh:
____________
JDM ST185H A-Spec:
warracer
Re: no spark
Postby zak062 » Wed Jul 03, 2013 1:25 am
Heres a nive little video. Notice how the tach does not bounce. As well as no check engine light coming on. Which is definatly weird since I always had one on due to removing the air to water intercool for a air to air.
I apologise for it being upside down. Smart phones arnt so smart
http://static.photobucket.com/player.sw ... 34f460.mp4
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
Re: no spark
Postby warracer » Wed Jul 03, 2013 2:01 am
man this reminds me of my last winter , bad times... :(
____________
JDM ST185H A-Spec:
warracer
Re: no spark
Postby zak062 » Wed Jul 03, 2013 2:06 am
Yea. At least I have another car to dd. It really bugs me that the check engine light isnt on at all. Any idea what would cause that?
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
Re: no spark
Postby zak062 » Thu Jul 04, 2013 1:06 am
New update. Car has no fuel pressure either. Now im really confused.
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
Re: no spark
Postby Tecker185 » Thu Jul 04, 2013 1:20 am
Check the distributor, if the ecu does not see the engine turning over it will not turn the pump on. My money is on the distributor.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Re: no spark
Postby zak062 » Thu Jul 04, 2013 1:33 am
Tecker184 wrote:Check the distributor, if the ecu does not see the engine turning over it will not turn the pump on. My money is on the distributor.
You owe me money then. I just the +b and fp terminals on the diag port. And she fired right up.
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
