Fuel pump failing?
Fuel pump failing?
Postby lalojamesliz1 » Fri Sep 08, 2017 8:15 pm
Hey guys, how do you know when your fuel pump is going out? My fuel pump relay has a spade/connector that shows it's been through some heat because the plastic is a little deformed around it.
Here's a small video on idle
https://youtu.be/g6dzErDmW5s
My afr's while cruising also bounce around from high 13's to high 14's
I remember it being solid high 14's befors with the gen2 engine years ago before I sold my car.
91 Celica all-trac gen3 swap
87 toy 5speed long bed
69 mustang
08 sequoia
14 avalon
and a 2 car garage :shoots:
lalojamesliz1
