Removing door lock actuator/door handle
Postby lalojamesliz1 » Thu Oct 12, 2017 12:38 am
I'm trying to replace my door lock actuator but I can't remove the rod that goes from the actuator to the door handle. That yellow clip that holds the rod is causing the problem.
Anyone know how to properly remove It?
08 sequoia
14 avalon
and a 2 car garage :shoots:
lalojamesliz1
Re: Removing door lock actuator/door handle
Postby lalojamesliz1 » Thu Oct 12, 2017 12:56 am
Here's a pic
08 sequoia
14 avalon
lalojamesliz1
Postby lalojamesliz1 » Thu Oct 12, 2017 2:36 am
Got it, I used my Dremel to cut off the end of the rod and it slid out then I installed the replacement. Yay! Who's driver power lock work now?
This guy 8)
08 sequoia
14 avalon
lalojamesliz1
Postby underscore » Thu Oct 12, 2017 4:12 am
From memory you pop the one end of the clip off, then rotate it and remove it.
Postby lalojamesliz1 » Thu Oct 12, 2017 8:41 am
So you mean the way I did it wasn't correct :D
Either way it's replaced :) . It was annoying to unlock the alarm and then use the key to unlock my door.
08 sequoia
14 avalon
lalojamesliz1
