Weird st205 AFR's while cruising
Postby lalojamesliz1 » Mon Nov 13, 2017 2:49 pm
Does this look normal for a st205 engine/ecu set up?
I have no CEL and the o2 sensor was replaced by the PO but he ran the st205 swap with the oem 540 injectors with a st185 ecu so he ran it rich at low rpms :doh:
Luckily he said most of his miles were Hwy. He said......
A long time ago when I had the gen3 electronics (mr2 ecu) on my gen2 engine the afr's were solid while cruising at the normal 14.7ish afr's
https://youtu.be/2uanaHEUztw
08 sequoia
14 avalon
and a 2 car garage :shoots:
lalojamesliz1
