Is the map sensor supposed to make a noise?(st185)
Postby superboonan » Wed Jan 03, 2018 10:11 pm
I just got my st185 engine rebuilt and I didn't really get to drive it much before that. And know I hear a kind of buzzing noise from the sensor that I think is the map sensor (located near where the wire loom enters the interior) I also noticed that the thingy that adjust idle is vibrating at certain rpms.
Is it supposed to have a noise or is it broken or do I have vaccum lines hooked up incorrectly
superboonan
Re: Is the map sensor supposed to make a noise?(st185)
Postby Magroo » Thu Jan 04, 2018 2:13 am
I think that's the AC idle up valve you might have the vacuum lines hooked up backwards. Don't quote me on that I might be wrong.
Magroo
Postby superboonan » Mon Jan 15, 2018 1:19 pm
Magroo wrote:I think that's the AC idle up valve you might have the vacuum lines hooked up backwards. Don't quote me on that I might be wrong.
turn out that was the problem thank you very much for saving me hours
superboonan
