what connector is this? found unconnected behind center pann
Postby superboonan » Wed Jan 10, 2018 7:43 pm
I was taking apart the center panel on my st185 when i found a unconnected conncetor, does any one have a clue what it does and how i haven't noticed it earlier
superboonan
Re: what connector is this? found unconnected behind center
Postby Magroo » Thu Jan 11, 2018 5:34 pm
I think it's for the airbag computer? I remember having to move it out of the way when I changed my shifter assembly.
Magroo
Postby yyonline » Thu Jan 11, 2018 5:46 pm
Cruise control ECU. Connector and wire colors match the wire diagram.
yyonline
Postby superboonan » Thu Jan 11, 2018 6:00 pm
yyonline wrote:Cruise control ECU. Connector and wire colors match the wire diagram.
I I don't have cruise control nor do I have an airbag, can it still be that even though it never was fitted with those
superboonan
Postby 93celicaconv » Sat Jan 13, 2018 10:24 pm
Do you have a USDM ST185? If so, they all originally came with cruise control and air bags, best to my recollection. Your VIN would tell you what region the ST185 was originally built for.
93celicaconv
Postby superboonan » Mon Jan 15, 2018 1:20 pm
It was sold as new in sweden 1991
superboonan
Postby 93celicaconv » Mon Jan 15, 2018 2:24 pm
OK, that explains it. My 1990 & 1991 Celica ST's (AT180) did not come with cruise control, but when I pulled the cruise control system out of a salvage car, that same cruise ECU connector was in both of my ST's, so I suspect the Toyota wiring harness was the same regardless if the vehicle came with cruise or not. The connector for the cruise actuator was there also, so electrically, it was no issue installing this system. I suspect your ST185, if it did not come equipped with cruise control, has the wiring for it there anyway.
93celicaconv
