Recommendations for passing wiring through the firewall
Postby Numbchux » Tue Apr 10, 2018 7:38 pm
Installing an Arduino-based LCD in place of the clock that will display some engine information, including WBO2. Not seeing a great place to pass wires through the firewall. Any recommendations?
-Chux
'91 Celica GT vert, poly bushings, rear discs, etc., DD
'87 unTurbo 4Runner, 4.3 swap, 35s
'89 Subaru XT6, 2.7L Flat 6, AWD, awesome
'84 Subaru Brat, 4" lift, 29s, Impreza engine, 4.444s
Numbchux
Re: Recommendations for passing wiring through the firewall
Postby underscore » Tue Apr 10, 2018 8:11 pm
Which side do you need to come through? Some people use the spot the wire harness goes through.
Postby Numbchux » Wed Apr 11, 2018 5:33 pm
Could go either side. There's more room/access on the passenger side, but if there's a decent spot on the driver's side, that'd be fine.
The factory bellow where the wiring goes through is super easy to access in the engine bay, but I can't see it without taking the HVAC stuff out on the interior side.
-Chux
Numbchux
Postby underscore » Wed Apr 11, 2018 7:21 pm
I don't think many spots are visible from the inside, I usually pick a spot near the top and use a stiff piece of wire to feed it down to where I can reach it.
Postby GT4times2 » Fri Apr 13, 2018 12:42 am
How big is the harness? I'd run it through the driver side (through the fender), by the air box area.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby Numbchux » Fri Apr 13, 2018 1:02 pm
GT4times2 wrote:How big is the harness? I'd run it through the driver side (through the fender), by the air box area.
All said and done, probably 8-10 wires. Most are signal wires, so 18-20 gauge would be fine. But the WBO2 is going to need 2-3 heavier gauge ones.
It didn't occur to me to go through the fender....I'll have to look into that. I think I'll finally have some time to work on it this weekend. "Luckily" we keep getting snow, so I have plenty of time before I can drive it :x
-Chux
Numbchux
