Clutch pedal weirdness.....SOLVED !
Postby JRWperformance » Fri Apr 27, 2018 3:36 pm
Is there a trick to bleeding the clutch hydraulics on the celicas? I have an ST165 with a 4th gen swap and an ST205 trans with a stronger southbend clutch.
I bled my clutch with the clear tube on the bleeder method. I use a 6 foot length of clear vinyl tube and I work the pedal back and forth slowly watching the brake fluid level come up and the bubbles rise out.
The problem is, I have to push the clutch all the way to the floor to shift gears. Ive adjusted the rod length on the clutch master to where I still have a tiny bit of free play at the top of the pedal. The pedal does not feel like it is building pressure until it gets close to the floor.
Both the clutch master and slave are new and are both replacement parts for the ST165 chassis. Im not sure if there is a difference in piston sizing with the ST205.
Anyone else have problems with stronger aftermarket clutches?
Last edited by JRWperformance on Sat Apr 28, 2018 10:20 pm, edited 1 time in total.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Re: Clutch pedal weirdness.....
Postby underscore » Fri Apr 27, 2018 6:20 pm
I know someone sells extended slave rods (Speed Source I think?) for use with aftermarket clutches, I assume to correct this problem.
Postby Tecker185 » Fri Apr 27, 2018 11:13 pm
Ive had that problem before, i replaced my clutch master with an advance auto unit. Hard to bleed and when i got it bleed it only had good pedal towards the floor. I swapped the new one out for a known good used oem toyota and it worked fine.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby JRWperformance » Sat Apr 28, 2018 10:20 pm
Finally figured out this issue! The ST205 box I have in my ST165 has a different piston size in the clutch slave! I measured it at about 22mm and the ST165 is about 20.5mm. I put the smaller piston slave and the clutch is perfect!! Did not think there was a difference. Maybe the pedal in the ST205 is a different length or a different master cylinder size. Hope this helps anyone else having clutch issues!
88 Celica Alltrac
78 Honda GL1000
JRWperformance
Re: Clutch pedal weirdness.....SOLVED !
Postby zaluss » Sun May 27, 2018 7:31 pm
What did you measure exactly?
zaluss
Postby JRWperformance » Mon May 28, 2018 2:08 am
zaluss wrote:What did you measure exactly?
the clutch slave piston size....its in my post.
88 Celica Alltrac
78 Honda GL1000
JRWperformance
Postby zaluss » Mon May 28, 2018 4:00 am
Sorry I think I'm confusing the rod and the cylinder when you reference piston. I'm having the same issue :)
http://imgur.com/Q6T3EhG
zaluss
