St165 with 4th gen swap AC
Postby dbucks2k » Wed Aug 01, 2018 11:28 pm
I've had my st215 engine running in my st165 for over a year. When I did the swap I didn't install the AC. Now I want to put it in cause it's getting hot. I have almost everything figured as far as wiring. My only question is with the ECU. The st165 ECU had one pin that had something to do with the compressor clutch. The st215 ECU has two pins that go directly to the AC computer. Can I just wire it as was done originally in the st165 and not worry about the ECU? Or does anyone know to include the new ECU?
dbucks2k
Re: St165 with 4th gen swap AC
Postby GT4_DRED » Thu Aug 02, 2018 1:39 am
Hmmm, not sure. Why not use the st165 compressor to make things easy? :shrug:
'00 SC300 - "Big Butt"
'88 ST165 - "Rahtid"
'88 ST165 - "Supah Cyat"
'88 ST165 - "Cornbeef"
'88 ST165 - "Redhead"
'91 MR2-T SMG
'92 MR2-T Nautical Blue
GT4_DRED
Postby dbucks2k » Thu Aug 02, 2018 4:59 am
The compressor isn't the problem I'm having. It's the wiring of the ECU. I'm wondering how to make the st165 ac system work with a st215 ECU.
dbucks2k
Postby black88alltrac » Fri Aug 03, 2018 5:25 pm
i think the wiring to the ecu is only to control an ac idle up valve. otherwise i wouldnt worry bout it, you do need to make sure the ac amplifier sees the tach signal from the igniter. or you could just hard wire the a/c to come on with a/c button and bypass the pressure switches/safeguards.
black88alltrac
