4th gen swap boost controller question...
Postby JRWperformance » Wed Sep 12, 2018 4:18 am
Running a mostly stock spec gen 4 in my ST165. It has rods and pistons upgraded, but stock compression stock turbo. My intercooler and exhaust are upgraded and funtion well according to air intake temps from JOBD data. Ive been trying to up the boost but can seem to get it to go over 14...maybe spikes to 15 sometimes. I put my simple manual boost controller in series with the line off the compressor housing, to the inlet of the boost controller(pressure under the ball valve) then out to the line on the wastegate. The other line off the wastegate is capped off.
What is the normal way gen 4 guys are controlling boost? Im I missing something? Car runs awesome though. Very quick.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Re: 4th gen swap boost controller question...
Postby JRWperformance » Fri Sep 14, 2018 12:34 am
Wow...no one on here has turned up the boost on their 4th gen?
88 Celica Alltrac
78 Honda GL1000
JRWperformance
Postby dbucks2k » Fri Sep 14, 2018 3:17 am
I just disconnected the stock boost controller. And am running around 20 psi. Not the safest thing considering I still have stock rods. But it works good.
dbucks2k
Postby underscore » Fri Sep 14, 2018 5:03 pm
Get an air compressor and see what pressure the MBC is operating at. Whats fuel cut at on a gen 4?
Postby dbucks2k » Mon Sep 17, 2018 12:20 am
Just read again how you routed it. Your aftermarket boost controller should go between the compressor port and the wastegate. The line coming off the wastegate to the stock boost controller should be blocked off.
dbucks2k
Postby dbucks2k » Mon Sep 17, 2018 12:31 am
This picture shows it better. The cirlce is where you should put your aftermarket boost controller. And disconnect the lines off the stock boost controller and block them where the X's are
dbucks2k
Postby JRWperformance » Mon Sep 17, 2018 3:01 pm
Thats how mine is routed. Ok, cool. I just wanted to verify.
88 Celica Alltrac
78 Honda GL1000
JRWperformance
Postby UtahSleeper » Tue Dec 11, 2018 1:02 am
Late to this party lol.
I run the st215 engine with a MBC and kept it at about 12-13 PSI. Everything I had read is that the stock turbo doesn't really offer anything over that and will just cause earlier death, so I stayed safe.
UtahSleeper
