ST165 Factory Oil Pressure Gauge, typical readings?
• Page 1 of 1
I just bought an ST165 (88 Turbo All Trac). The oil pressure gauge is always reading seemingly low, always in the 10 to 15% range. The dealer says that is normal, but it doesn't seem right. Where do you fellow ST165 drivers see your needle pointing during normal driving conditions?
- mickeyfinn
- Newbie
Re: ST165 Factory Oil Pressure Gauge, typical readings?
mickeyfinn wrote:I just bought an ST165 (88 Turbo All Trac). The oil pressure gauge is always reading seemingly low, always in the 10 to 15% range. The dealer says that is normal, but it doesn't seem right. Where do you fellow ST165 drivers see your needle pointing during normal driving conditions?
That’s normal readings.
- Gt4grey
At idle, my needle sits at just a tick below halfway on the at first bar.
'88 ST165...All-Trac
http://www.toyotacelicaonline.com/112rick.htm
'89GTS...Old Faithful
http://www.toyotacelicaonline.com/067rick89gts.htm
Rick89GTS - GTFour God
• Page 1 of 1
