Anyone have a charcoal canister check valve & jet?
Postby FC Zach » Mon Dec 03, 2018 4:33 am
I've almost completed the charcoal canister connections since purchasing the correct water outlet with a BVSV. . now I just need these two pieces and I'll be done. I can get them new (the jet I've found online but the check valve I'm unsure of) and may have to but I was hoping someone may have these laying around and can part with them.
In case anyone may wonder. . It may seem like a lot of trouble to connect something most discard (I assume at least). I'm wanting to connect this system because there have been times when I could smell gas fumes from the engine bay. I also have a natural gas water heater in the garage. . directly in front of the Celica.
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Re: Anyone have a ccharcoal canister check valve & jet?
Postby FC Zach » Mon Dec 03, 2018 4:42 am
Oh! That diagram is from a Chilton repair manual. . in case any of you have one. This is obviously a misprint :?
1993 Yamaha GTS1000
FC Zach
Images: 9
Re: Anyone have a charcoal canister check valve & jet?
Postby Magroo » Mon Dec 03, 2018 6:48 pm
I might have that piece. Its probably still attached to my canister I removed.
I'll check later at work right now. Hard part will be finding what box it's in.
Magroo
Postby r-town » Tue Dec 04, 2018 6:40 am
FC Zach wrote:In case anyone may wonder. . It may seem like a lot of trouble to connect something most discard (I assume at least). I'm wanting to connect this system because there have been times when I could smell gas fumes from the engine bay. I also have a natural gas water heater in the garage. . directly in front of the Celica.
I need to have mine because of California, else I have to pay the big bucks. :cry:
r-town
Postby FC Zach » Tue Dec 04, 2018 7:26 am
r-town wrote:I need to have mine because of California, else I have to pay the big bucks. :cry:
Fortunately for us TN residents, we only have the sniff test (for cars '95 and older) and a code check for OBD2 as well as visual check for exhaust/gas cap for all. . There are only six counties in the state doing the smog test (I'm in one of them),there have been votes to remove it completely :notworthy: so it's only a matter of time before I no longer have to deal with the hassle :D
With all that being said, it's not like I'm driving a modded diesel that's rolling coal. . Although I have zero cats, no EGR, and only pass visual because 'I know a guy'. . The test is always a pass. Hell, the car practically shits daisies according to their test machine :) I don't how but it does.
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby r-town » Mon Dec 10, 2018 10:24 pm
California labels my ST185 as a gross polluter. Right now is non-op, but last time I took it to the smog test center the guy literally did an EGR vacuum test to make sure it operated properly. Since its AWD, they simply do the sniff test + visual inspection.
r-town
Postby superboonan » Tue Dec 11, 2018 7:57 am
I think I have it somewhere, :) when do you need it?
superboonan
Postby FC Zach » Tue Dec 11, 2018 7:58 am
No rush, whenever convenient for you.
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby superboonan » Tue Dec 11, 2018 8:07 am
FC Zach wrote:No rush, whenever convenient for you.
well I'm actually from Finland but I'm going to Washington in early January and so I think I should be able to ship it from there cheap
superboonan
Postby FC Zach » Tue Dec 11, 2018 8:28 am
That would be great! I think Magroo is checking for them. . If I get these pieces from him before then, I'll let you know. Thanks!
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby superboonan » Tue Dec 11, 2018 8:31 am
FC Zach wrote:That would be great! I think Magroo is checking for them. . If I get these pieces from him before then, I'll let you know. Thanks!
great :D
superboonan
Postby Magroo » Wed Dec 12, 2018 12:47 am
Sorry Zach I completely forgot to check on those parts. I'll write myself a note to check on Thursday while I'm doing maintenance on the snow blowers.
No snow yet, but it's not far off. Need to make sure they fire up when needed.
Magroo
Return to Parts Wanted
