Apexi evc boost controller
Postby oka » Mon Mar 04, 2019 2:13 am
Im having a hard time setting my boost to 15lbs. The settings are really confusing. Like where to set the dutty cycle etc. can anybody help me please. Thanks
st165..04 ls430 vip
oka
Re: Apexi evc boost controller
Postby hoys » Tue Mar 05, 2019 12:46 pm
Boost controllers don't set "boost" in PSI. You are setting how active on a time scale (or duty cycle) a solenoid is that bleeds air. The amount of time spent bleeding off air then dictates how much boost pressure the turbocharger is able to create.
Do you have an Apexi or HKS boost controllers? HKS has a model "EVC" where Apexi does not.
hoys
Postby oka » Wed Mar 06, 2019 4:35 pm
Apex. I set it to 1 bar. But whenever i floor it on 3rd4 and 5th, it boost over and hits fuel cut. It has a 3 gen motor. Thanks
st165..04 ls430 vip
oka
Postby oka » Wed Mar 06, 2019 4:38 pm
Duty cycle is set at 73%
st165..04 ls430 vip
oka
Postby hoys » Wed Mar 06, 2019 4:58 pm
Lower the duty cycle and try again.
hoys
Postby One-TracMind » Wed Mar 06, 2019 10:09 pm
I have an HKS EVC-S and it does the same thing. Super frustrated trying to figure it out ever since I installed it. Even adding an FCD didn’t solve the issue!
One-TracMind
Return to FAQ / Archive
