Red Line 75W90NS or....
Postby lalojamesliz1 » Mon Apr 08, 2019 1:46 am
I put Red Line 75W90NS in the original trans for my st185 when it had like 152 or 153k miles. It developed a crunch while shifting into 4th above 35mph or downshifting into 4th from 5th. Strangely that problem came, left then came back. Now my all-trac is parked waiting for my st205 swap to arrive.
Can you guys reccomend something that will provide better protection for my e154f trans?
08 sequoia 5.7L
14 avalon
02 taco dbl cab V6 turd
and a 2 car garage :shoots:
lalojamesliz1
Re: Red Line 75W90NS or....
Postby 93celicaconv » Mon Apr 08, 2019 3:05 pm
I don't know what your ST205 swap calls for proper trans oil. The original ST185, when I studied this closely regarding the proper oil for that particular quadruple case, I could only find two that I would have been comfortable using, and I opted for the first one listed below of these two:
- Toyota Gear Lube Super GL-5 75W-90
- Castrol Multitrax (I believe Castrol discontinued this product in early 2017, replacing it with Cartrol Universal, which I did not research back in 2016 when Multitrax was readily available - I don't believe Castrol Universal is sold in the US though)
These are the only two that singled out the Celica GT4/All-Trac 4WD on their labels about working with.
I also considered the specific RedLine oil you used on yours, but when I contacted the manufacturer about the application, all I got was "it should work" from the applications person I spoke to (and it doesn't call out this particular application on the label anywhere), so I opted against considering it.
93celicaconv
Images: 26
Postby sefiroxx » Mon Apr 08, 2019 8:37 pm
Plenty of posts on gl/4 vs 5 and impact on synchro. At issue is the sulfur/phosphorous additive that was added to improve things eats the older syncros.
I run redline mt-90 without any problems. Any good performance shop should stock. Can get online as well.
sefiroxx
Postby lalojamesliz1 » Mon Apr 08, 2019 10:27 pm
sefiroxx wrote:Plenty of posts on gl/4 vs 5 and impact on synchro. At issue is the sulfur/phosphorous additive that was added to improve things eats the older syncros.
Thanks for sharing that, I think I'll try that. I remember getting some of the mt90 for a older 5 speed Toyota pickup because it was supposed to be really good.
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby MWP » Tue Apr 09, 2019 9:59 am
MT-90 isnt GL5 rated, and wont protect the hypoid gear in the transfer case properly.
This topic has come up 1000 times in this forum.
Redline 75W90NS is the one the majority of people (including me) recommend.
If your gbox has problems while running 75W90NS your gearbox needs a rebuild. No oil is going to fix it for you.
[color=Blue]Daily:
Toyota RAV4 ACA23R
Race-Car: Toyota GT4 ST185 5S-GTE
Postby lalojamesliz1 » Tue Apr 09, 2019 12:51 pm
MWP wrote:MT-90 isnt GL5 rated, and wont protect the hypoid gear in the transfer case properly.
Whew, that was close. I was about to order some. :D
That trans was abused I'm sure. 155k miles is good for what probably its been through
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby sefiroxx » Tue Apr 09, 2019 7:43 pm
Oops, my bad, was focused on the crunching and got my solutions for gt vs alltrac mixed up. (My 4x4 trucks have separate cases for tranny vs transfer)
Yes, mt-90 is NOT to be used for hypoid gears.
Good catch
sefiroxx
