Rear Arm Poly Bushes
Postby alltrac801 » Mon Jun 10, 2019 8:40 pm
So I just received my rear arm poly bushes from GT4-Play and I just want to know if these are pressed into the rear suspension arms?
https://gt4-play.co.uk/shop/celica-gt4- ... y-bush-set
And I also ordered the spherical hub bushes as well and want to know if those are pressed in?
https://gt4-play.co.uk/shop/toyota-sphe ... bushes-834
alltrac801
Re: Rear Arm Poly Bushes
Postby 93celicaconv » Tue Jun 11, 2019 12:55 am
The spherical bushings are pressed into the rear carriers (knuckles). The other bushings attached at the sub frame are pressed into the arms (my understanding).
93celicaconv
Images: 26
Postby alltrac801 » Tue Jun 11, 2019 3:44 am
Okay that's what I assumed but I wanted to make sure before I started taking everything apart. Thank you!
alltrac801
Postby sefiroxx » Tue Jun 11, 2019 4:12 am
The rear arm bushings you purchased are split and don't need to be pressed in.
sefiroxx
Postby alltrac801 » Tue Jun 11, 2019 2:27 pm
So only the hub bushing need to be pressed in?
alltrac801
Postby sefiroxx » Sun Jun 16, 2019 12:15 am
The oems are pressed in. Can't really tell from your picture if yours are split or not. It looks like they are set in a temporary sleeve that will make pressing easier so I would assume yes.
sefiroxx
