I bought a 1990 ST185 project and the shifter never worked at all. It came with an aftermarket shift lever and I believe it is the cosmo racing short shifter with the stock housing (1990). The springs that are on the housing seem to be too weak to bring it back to neutral and it feels really shitty when you do get it into gear. I also have no idea if the shift linkages were changed or anything...
Can somebody also explain how I can shift through the gears by using the 2 levers on the actual transmission.
All help and advice is greatly appreciated! Thanks!
