1990 JDM ST185 Narrowbody
Postby HiuBin » Tue Sep 03, 2019 10:53 pm
This is the build thread for my JDM ST185 Narrowbody (true japan-only spec car). I've been a Celica owner since 2012, my first one being a 1993 GT coupe, then a 1994 GT liftback.
1993 GT Coupe: no mods, essentially. Didn't have any kind of money to work on it and I enjoyed driving it as is. It was also my first-ever stick-shift car.
1994 GT Hatch: Started out with a barely-running car. Gave it some much needed TLC. Fast forward a year later, I swapped a 98+ 5SFE, and it had an eBay t3/t4 turbo setup on a Megasquirt-2, which made 214whp before blowing up cyl #3. Learned a bit about engines, decided to gap the piston rings and hone the cylinders to install the new rings on all 4 eBay pistons. That time, I was able to obtain close to 300whp on a TD06SL2-20G kinugawa internal-wastegate turbo. @ 21psi with meth injection, then blew up cyl #1 & 3. Put in a set of Arias Pistons, Maxpeeding Rods, ARP headstuds. ~350whp @ 27psi on a T3/T4 turbo again, this time a smaller .50/.48A/R, running a Megasquirt 3X tuned by myself.
That last setup ran for 3 years, before taking it out to sell it for 1000$ as-is, to make room for a Gen4 3SGTE, TRD LSD from a MR2-S. Ran it for a little bit before selling it to move to mainland US. That was in 2018.
Now, I own a ST185, back to my roots, but this time with traction on all four wheels like it should be.
With that little, non-detailed background of me, I will begin this build thread as sort of an interactive diary. Heavy mods are incoming for this car. I continue running this unmolested Gen2 3SGTE for a while. I will build a Gen5 3SGTE to swap it into the car for power instead. I would like to be able to sell this 92-93K current-miles JDM 2nd Gen 3SGTE with full harness and ECU.
Pics coming soon! Once I get them uploaded somewhere. Haven't been in a forum for a while.
In the beginning:
First thing I did was some maintenance. Changed oils, fixed a bent rear trailing arm.
First mods were BC Racing BR Coilovers and 17x8 +40 Konig Hypergram in Race Bronze. This is how it looks now.
I also swapped out the front brakes from ST165 brakes that came stock on this (255mm rotor, 2 pot calipers) to the ST185 setup which is completely bolt-on as expected.
Gratuitous unmolested engine bay pic for you purists out there:
HiuBin
Re: 1990 JDM ST185 Narrowbody
Postby FC Zach » Wed Sep 04, 2019 5:20 am
Welcome!
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby HiuBin » Wed Sep 04, 2019 12:49 pm
FC Zach wrote:Welcome!
Thanks!
HiuBin
