Which steering rack is a good replacement?
Postby awdmofo » Fri Sep 27, 2019 6:09 pm
My 90 rebuild is going slow but i need to ramp it up! body has 213K miles on it, with the engine/trans out I'm replacing every line basically and removed the rack. need help picking a replacement, anyone every replace theirs with a Cardone, AC delco or BBB? prices are $150/175/180 for these, and have 3/36k warranties. Or is better to just have my stock one rebuilt and buy new end tie rods? Thanks guys! :notworthy:
2nd gen Part out! https://www.alltrac.net/phpBB2/viewtopic.php?f=15&t=53417&p=489623#p489623
Full interior part out! https://www.alltrac.net/phpBB2/viewtopic.php?f=15&t=53399
awdmofo
Re: Which steering rack is a good replacement?
Postby sefiroxx » Fri Sep 27, 2019 6:25 pm
I put a cardone remain in 5 years ago, running great still allthough I am worried about cardone quality on most of their parts.
sefiroxx
Postby awdmofo » Fri Sep 27, 2019 9:38 pm
sefiroxx wrote:I put a cardone remain in 5 years ago, running great still allthough I am worried about cardone quality on most of their parts.
which part? end rods? inner? seals? I need to find that steering rack rebuild quote I got, might be about the same to keep it OEM but i dunno what manufacture the seals and whatnot they would be using.
awdmofo
Postby JRWperformance » Fri Sep 27, 2019 11:20 pm
I got a Maval reman unit for my 165. Works great. Also found it crossed to the toyota Camry of the same era.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Postby sefiroxx » Sat Sep 28, 2019 12:28 am
I did the full rack with warranty. The original rack was leaking at the seals. I needed to minimize the downtime and could not wait for reman/reseal on the original.
sefiroxx
Postby awdmofo » Sun Sep 29, 2019 12:28 am
JRWperformance wrote:I got a Maval reman unit for my 165. Works great. Also found it crossed to the toyota Camry of the same era.
Looks like the maval is the most expensive option for a 185 so far at $210 + 125 core. It seems they only have a 2/24 warranty so i might not go that route. What outer tie rods did you use? I can see mine on the car are junk lol.
awdmofo
Postby awdmofo » Sun Sep 29, 2019 12:29 am
sefiroxx wrote:I did the full rack with warranty. The original rack was leaking at the seals. I needed to minimize the downtime and could not wait for reman/reseal on the original.
Ahh i get you. What did you decide to use for outer tie rods? I got some time so a rebuild on the OEM unit is an option but I don't want to pay $150+ for a rebuild i think. Did you replace/add a filter in the line? I see these inline filters on Amazon and mentioned in other parts websites when im looking around for the rack.
awdmofo
Postby sefiroxx » Sun Sep 29, 2019 1:11 am
Still running the tie rods, installed by a repair shop 15 years ago.
The seals on the rack were probably destroyed by gunk from the pump when it went bad.
No filter installed.
sefiroxx
Postby awdmofo » Tue Oct 01, 2019 4:07 pm
sefiroxx wrote:Still running the tie rods, installed by a repair shop 15 years ago.
Geez 15 years on tie rods! i wonder which brand they used.
Yea i think i might install this filter thingy since i'm rebuilding or swapping for a remain pump along with new lines and new rack...
awdmofo
Postby sefiroxx » Tue Oct 01, 2019 6:55 pm
Yep, long time.
Car is long trip, mostly highway, weekly. Used to get to referee assignments throughout North Texas.
(04 Work truck is on 3rd set of outer and 2nd set of inner tie rods. Lots of curbs, gravel etc )
sefiroxx
Postby awdmofo » Sat Oct 05, 2019 5:47 pm
sefiroxx wrote:Yep, long time.
Nice, this car is going to be street driveable (for now) but mostly used for track and rally. going to gut it soon and build up the brakes and susp with the 300ish hp engine im rebuilding before i build a 400hp+ monster engine/trans for full race. I use to referee ice hockey with my older brother, what d you referee?
So i fould a shop that rebuilds these for $150, i'm just curious if that includes new inners and outer or just inner replacements. They said I could swap my rack for a rebuilt one for the same price, but im trying to keep this as OEM as possible.
awdmofo
Postby underscore » Sat Oct 05, 2019 7:28 pm
Personally I'd grab a junkyard 2WD rack to send in as the core, and keep your original one for any future purposes.
Postby awdmofo » Sat Oct 05, 2019 7:50 pm
underscore wrote:Personally I'd grab a junkyard 2WD rack to send in as the core, and keep your original one for any future purposes.
Good idea but im running low on time and I have a new job I start in a few weeks so I need to finish a lot of my rebuild before I have to move :cry:
awdmofo
Postby sefiroxx » Sat Oct 05, 2019 9:17 pm
Agreed, I have enough spare parts to build another car. I have extra rack, drive shafts, compressor etc that are ready to install. The old ones pulled get gently in my spare time and stocked for future install.
Referee - currently soccer and formerly lacrosse.
sefiroxx
Postby awdmofo » Sun Oct 06, 2019 3:58 pm
sefiroxx wrote:Agreed, I have enough spare parts to build another car. I have extra rack, drive shafts, compressor etc that are ready to install. The old ones pulled get gently in my spare time and stocked for future install.
I guess If i never plan to sell this guy I could keep some more parts around. I'm selling my AC compressor now though because i plan to get another engine (3rd Gen 400+hp) later on and it will be a full clip i pick up.
cool, lacrosse seems fun.
awdmofo
