Power steering vacuum lines
Postby BayAreaAT » Tue Oct 01, 2019 5:16 pm
Can someone please tell me where those two vacuum lines from the power steering pump go.
Thanks
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
BayAreaAT
Re: Power steering vacuum lines
Postby sefiroxx » Wed Oct 02, 2019 7:40 pm
Provides idle up ability on extreme end of turning when the pump is working the hardest. One hose is tied to clean air, the other to the intake. Power steering pump opens the valve.Image
sefiroxx
Postby BayAreaAT » Thu Oct 03, 2019 7:36 pm
Thank! You’re awesome!
By the. I don’t remember having to bleed the air out.
Chris M.
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT
Postby sefiroxx » Thu Oct 03, 2019 8:23 pm
No need to bleed, pump will push air/fluid through the system into the reservoir where air will rise to the top.
Move the steering wheel side to side as far as it will go to help clear the system.
sefiroxx
