ST205 Fuel Bracket
• Page 1 of 1
ST205 Fuel Bracket
Does anyone know for 100% sure that the fuel pump bracket from the ST205 will fit into the ST185 fuel tank, and work properly without any modifications?
For reference, here are the parts:
https://www.nengun.com/oem/parts/MjM0OT ... N0ZW0gMg== This is the ST205 one, it has a different bend in the long metal part, which I'm not sure I could detach if it didn't fit.
And here is the ST185 one that I need to replace: https://www.nengun.com/oem/parts/MjM0OD ... N0ZW0gMg==
Also does anyone have an ST185 bracket for sale that's not completely rusty?
- 80's Kid
Re: ST205 Fuel Bracket
I can confirm an st205 fuel pump bracket needs to be chopped about an inch to fit in an st165 tank, the slight bend is still enough to fit into the fuel pickup area in the tank, but it needs to be shortened. I didnt need to do anything else but have the bracket shortened for an st165
- alltracandahalf
- Newbie
• Page 1 of 1
