I guess I'm supposed to do this to gain access to the rest of the forum! Been a member about a year and a half but didn't realize that my access to the rest of the board has been limited this whole time...weird
Purchased my ST185 spring of 2018. Rockers are a bit rusty but rest of the car is in good shape. Has the Whiteline suspension kit, I had to replace the Koni shocks with KYB AGX for the rears as they were blown when I bought the car. Replaced the power steering pump as it was leaking. Pulled the turbo and DP to replace with a 16G compressor on the CT26 OE spec turbine, installed 3" DP and replaced the oil cooler hoses while in there. Had to swap out the exhaust manifold as well as it was cracked. Put in AEM X-series wideband and boost gauge as well. Replaced the steering wheel with aftermarket Momo wheel and found some decent shape OEM leather seats to replace the cracked ones that came with the car. Also found some 6th gen wheels and tires to replace the steelies it came with.
