front ABS sensor replacement?
Postby EvilStig » Sat Dec 07, 2019 5:32 am
Has anyone found an ABS sensor replacement that is compatible with the ST185?
Also, who in the hell designed this car? :cry:
EvilStig
Re: front ABS sensor replacement?
Postby 93celicaconv » Sat Dec 07, 2019 2:10 pm
You should do a search in this forum, but I think there is a Camry ABS sensor that is a "very close" to match to the ST185, it requires a small bit of tweaking to make work, but I believe most have been successful with the tweak.
What corner do you have a need foe an ABS sensor?
93celicaconv
Images: 26
Postby EvilStig » Sat Dec 07, 2019 3:08 pm
93celicaconv wrote:You should do a search in this forum, but I think there is a Camry ABS sensor that is a "very close" to match to the ST185, it requires a small bit of tweaking to make work, but I believe most have been successful with the tweak.
passenger front so far... no idea yet if I'll be successful in getting the other hubs off without breaking them.
I did search the forums but couldn't find specific part numbers. :(
EvilStig
Postby 93celicaconv » Sat Dec 07, 2019 5:18 pm
EvilStig wrote:passenger front so far... no idea yet if I'll be successful in getting the other hubs off without breaking them.
Below is what I have for ABS Sensor P/N's for the ST185. Unfortunately, the front RH & LH are not labeled as the rear RH & LH are. Based on Toyota logic, I would say the top P/N listed is the front RH, and the one below is the front LH, but that is only a guess on my part. The parts were also used on ST185's in Europe & Japan, so those locations may still have some. Japan also used these parts on their Carina cars, so you may have better luck from a source in Japan for a direct replacement.
89542-20020 (09/1989 - 07/1991)
89543-20020 (09/1989 - 07/1991)
89545-20060 REAR-RH
89546-20060 REAR-LH
93celicaconv
Images: 26
Postby silverarrow » Sun Dec 08, 2019 9:18 am
Try hitting up your local engine importers, sometimes they have front clips laying around and they might part with the abs sensor for a price.
89 240sx
02 Nissan Frontier 4x4 Supercharged
silverarrow
Postby EvilStig » Wed Dec 11, 2019 6:53 am
89545-20060 REAR-RH
89546-20060 REAR-LH
After cutting off the remainder of the part I am able to confirm it is Part number 89542-20020 for the right (passenger) side.
on a hunch I snagged a cheap aftermarket replacement for part # 89542-07030 (2005-2012 Avalon and 2007-2011 Camry) on amazon Here. The barrel size and depth of the sensor is identical, as is the steering knuckle mounting bracket. However the Avalon sensor has a slightly raised collar near the base, so you need to use a 3/4" reamer or stepper bit to widen just the outer edge of the port to fit it in all the way.
The attached cable and routing is different but I don't care as I intend to splice the sensor on to my existing wire.
Won't know if it'll work until it's all back together but I have a good feeling the problem is solved for under $30 which has to be about the least painful fix yet for this car....
EvilStig
