1st Gen vs 2nd gen timing belt covers
Postby MatPop86 » Sat Mar 28, 2020 4:01 am
Are the timing belt covers on the 3SGTE the same for the 2nd gen or any other generations for that matter?
MatPop86
Re: 1st Gen vs 2nd gen timing belt covers
Postby 93celicaconv » Sat Mar 28, 2020 11:13 am
Assuming you are asking if the timing belt covers for an 88/89 All-Trac are the same on any other 3S-GTE engines. If this isn't a correct understanding, please be more clear in your question.
Top Belt Cover: 11322-88361 (used on 88-89 ST165 and 86-89 GTS w/3SGELC Eng)
- Used available at GT4-Play (https://gt4-play.co.uk/shop/st165-top-t ... oyota-used)
Bottom Belt Cover: 11321-88360 (same as top belt cover)
- Superseded to 11321-74030
- New available at Amayama (https://www.amayama.com/en/part/toyota/1132188360)
Rear Belt Cover: 11323-88380 (only on 88-89 ST165)
- Likely won't find this one anywhere - Toyota of Fort Worth says they have it to sell - but I doubt they have it
---- https://parts.toyotaoffortworth.com/p/T ... 88380.html
Good luck!
93celicaconv
Images: 26
Postby MatPop86 » Sat Mar 28, 2020 3:52 pm
That's what I was wondering, if the covers are the same through every generation
MatPop86
Postby 93celicaconv » Sat Mar 28, 2020 4:02 pm
The the answer is, at least from a part number perspective, the 1st Gen 3S-GTE timing belt covers used on ST165's are not the same across later models (ST-185/ST205). But at least 2 of the covers are also available on Toyota GTS vehicles with that particular engine.
Are you looking to acquire a set? Then hopefully the information previously provided will be useful for you.
93celicaconv
Images: 26
Postby MatPop86 » Sat Mar 28, 2020 4:08 pm
Thank you for the information. I bought my 165 without a top timing case and the lower cover just looks a bit scuffed. Thank you for the links
MatPop86
