Whirring noise with increase of RPMs
Postby Maet » Thu Jun 25, 2020 1:41 am
I just noticed a sort of whirring noise coming from my ST165 with the increase of RPMs. I know its nothing on my clutch side because I just put in a new one, but are the power steering pumps known to go out or have issues? That's where I feel like it's coming from. If so are the pumps the same on a standard model Celica of the similar year?
Maet
Re: Whirring noise with increase of RPMs
Postby 93celicaconv » Thu Jun 25, 2020 9:45 am
Noise problems are hard to discuss with messages in a forum. If you suspect the power steering pump, why don't you remove the belt from the pump and drive your car without power steering and see if the noise is still present or not.
Just be extra careful recognizing your ability to turn quickly and easily is no longer possible temporarily.
93celicaconv
Images: 26
Postby freddie » Fri Jun 26, 2020 12:52 am
Please lift the hood on your car and remove the cat that is trapped in there.
To check your power steering, while the engine is running turn the steering wheel full lock, hard and hold it there.
If there is a problem with the power steering pump, you will definitely hear it.
Check your belt tensioner pulley by just tightening it a bit.
Also check your alternator.
freddie
Postby Maet » Fri Jun 26, 2020 12:57 am
Lol my cat is hollow. Alternator belt is really tight, but I will check.
Maet
Postby Maet » Fri Jun 26, 2020 1:07 am
It doesn't make a noise when it's at full lock or if it's not moving, only a almost groaning noise when the wheel is being turned. Is that the belt?
Maet
Postby gt4tified » Sat Jun 27, 2020 5:15 am
Check the bearings on your alternator, a/c compressor and power steering pump, as well as the timing belt tensioner bearing.
Bringing back alltrac.net, one post at a time! :twisted:
Toyota Celica ST185 GT-FOUR RC
Mazda BT-50 pickup
gt4tified
Images: 5
