ST165 power steering belt/pump
Postby MatPop86 » Mon Jun 29, 2020 12:48 am
Do the non all trac Celicas have the same power steering system as the All Trac model if they are the same generation? My ST165's power steering belt is going out and I'm wondering if I can get a replacement for a GT Celica or something similar.
MatPop86
Re: ST165 power steering belt/pump
Postby underscore » Mon Jun 29, 2020 2:16 am
The belt should be the same for a ST162 GTS with a 3SGE.
Postby MatPop86 » Mon Jun 29, 2020 3:59 am
Alright thanks.
MatPop86
Postby 93celicaconv » Mon Jun 29, 2020 10:09 am
The power steering pump belt on your ST165 (90916-02205) is also used on the:
- 1990-1993 Celica's with 5S-FE & 3S-GTE engines
- 1994-1999 Celica's with 5S-FE engines
- 1992-1994 Camry's with 5S-FE engines
According to my information, the belt on an ST162 3S-GE engine is not the same.
I think this belt is still available from Bando (3PK760), but that would need to be verified that if it is exactly the same belt size.
93celicaconv
Images: 26
