Hi everyone,
I’m restoring an all trac and curious if the Quarter panels from a 5th gen GT liftback is interchangeable with a st184/st185?
The Lower rocker portion section behind the door is the area I really need. As you guys know, the GTS/All trac wide bodies are hard to come by and was hoping I can cut the lower portions off of a GT/Liftback if it’s identical. Thanks in advance!
