Correct rear drums
Correct rear drums
Postby abeans » Fri Sep 25, 2020 4:51 pm
Hi,
I'm having a hell of a time finding the correct rear drum hardware. - Rockauto has sent me the wrong parts (A recurring trend for this vehicle) want to make sure i get everything i need... Ended up buying the hardware from the UK
Whats a good drum hat for the ebrake that will for sure work?
1990 St185 Celica
abeans
Re: Correct rear drums
Postby abeans » Sun Sep 27, 2020 2:29 pm
Shoes shoes? Whats everyone run?
1990 St185 Celica
abeans
Postby RedCelicaTRD » Sun Sep 27, 2020 7:26 pm
I’ve never had to replace a set of the parking brake shoes. Is yours worn out or just replacing because it’s apart?
Postby abeans » Sun Sep 27, 2020 9:39 pm
RedCelicaTRD wrote:I’ve never had to replace a set of the parking brake shoes. Is yours worn out or just replacing because it’s apart?
Yes to both. There is basically no material left.
1990 St185 Celica
abeans
Postby jr32 » Mon Sep 28, 2020 3:29 am
From toyodiy.com (https://www.toyodiy.com/parts/p_U_19900 ... l?hl=46590):
46503 PLATE SUB-ASSY, PARKING BRAKE, RH
46503-20030 1 $358.72
46504 PLATE SUB-ASSY, PARKING BRAKE, LH
46504-20030 1 $358.72
46540 SHOE ASSY, PARKING BRAKE, RH OR CENTER NO.1
46540-20040 1 $25.70
46550 SHOE ASSY, PARKING BRAKE, RH OR CENTER NO.2
46550-20040 1 $25.70
46550E SPRING, TENSION, NO.2(FOR PARKING BRAKE SHOE RETURN)
90506-12010 2 $8.07
46550F SPRING, TENSION(FOR PARKING BRAKE SHOE RETURN, FRONT)
90507-16009 2 $2.89
46550J SPRING, TENSION(FOR PARKING BRAKE SHOE RETURN REAR)
90507-16009 2 $2.89
46580 SHOE ASSY, PARKING BRAKE, LH NO.1
46590 SHOE ASSY, PARKING BRAKE, LH NO.2
46590-20040 1 $25.70
47405A SCREW SET, SHOE ADJUSTING, RH(FOR PARKING BRAKE)
47405-30040 1 $63.14
47406A SCREW SET, SHOE ADJUSTING, LH(FOR PARKING BRAKE)
47406-30040 1 $63.14
47447D SPRING, COMPRESSION(FOR PARKING BRAKE SHOE HOLD DOWN)
90501-14049 4 $2.02
47447E PIN, SHOE HOLD DOWN SPRING, NO.1(FOR PARKING BRAKE)
47447-20030 2 $2.21
47447F PIN, SHOE HOLD DOWN SPRING, NO.2(FOR PARKING BRAKE)
47447-22020 2 $3.20
47449A CUP, SHOE HOLD DOWN SPRING, NO.1(FOR PARKING BRAKE)
47449-30030 8 $2.17
47456A PLATE, SHOE GUIDE(FOR PARKING BRAKE)
47456-20030 2 $1.11
47459B BOLT, SHOE GUIDE PLATE SET(FOR PARKING BRAKE)
47459-30010 2 $24.47
47611 LEVER, PARKING BRAKE SHOE, RH
47611-20030 1 $24.67
47611A WASHER, TYPE C(FOR PARKING BRAKE SHOE LEVER)
90213-07018 2 $1.19
47611B SHIM(FOR PARKING BRAKE SHOE LEVER)
90564-09184 T=0.3 X $2.21
90564-09185 T=0.6 X $2.21
90564-09186 T=0.9 X $2.21
47612 LEVER, PARKING BRAKE SHOE, LH
47612-20030 1 $24.67
47613D SPRING, COMPRESSION(FOR PARKING BRAKE SHOE STRUT)
90504-14002 2 $5.77
47613E STRUT, PARKING BRAKE SHOE, RH
47613-20040 1 $16.29
47614 STRUT, PARKING BRAKE SHOE, LH
47614-20010 1 $16.29
90179-10030 *** STD. PART $1.23
jr32
Postby jr32 » Mon Sep 28, 2020 3:31 am
jr32
Postby abeans » Mon Sep 28, 2020 12:58 pm
Awesome. I was hoping to avoid overseas, I did see several options there.
Toyodiy is a neat website, bookmarked.
1990 St185 Celica
abeans
