WTB: ST185 Transmission cooler lines (CLOSED)
Postby Tippo » Wed Apr 14, 2021 11:32 am
Hello all. I looked around to make the transmission cooler lines, but I'd like to see if anybody has them laying around.
Here's what we're looking at:
If anybody has these it would be greatly appreciated!
1992 SW20 MR2 Turbo 4th Gen 3SGTE Swap. Aquamarine Pearl. Project "Prissy"
1992 ST185 Celica All-Trac Turbo. Teal Metallic. Project "Lazarus"
Tippo
Re: WTB: ST185 Transmission cooler lines
Postby grip-addict » Fri Apr 16, 2021 11:40 am
You can make your own if you can't find the part.
https://youtu.be/VyHh2-UdCro
Note that AN fittings have very specific tq requirements and WILL LEAK if you don't follow the fitting/hose end manufacturer's instructions exactly.
Also an option is to get replacement hoses made. Some o'reilly's and other part stores will have a store in the district that can do it. Otherwise, call up a semi truck shop. They either can do it or will know where to go.
grip-addict
Postby Tippo » Fri Apr 16, 2021 12:29 pm
grip-addict wrote:You can make your own if you can't find the part.
Yup I researched that route pretty heavily, but I'm mostly interested in getting the stock lines in at the moment if they're out there and available. This car is stock from the factory aside from my current restoration (Supra TT fuel pump being the ONLY non-standard part). If all else fails, I'll go the creation route. It's fairly simple by the looks of it.
Tippo
Postby grip-addict » Tue Apr 20, 2021 8:52 pm
Making lines isn't too bad, it just takes time. blow out everything with air all of the time and deburr whenever possible and make sure your cut is as straight as it can be.
You probably don't need braided lines for the transmission cooler, but if you do end up using them, I ended up with the cleanest cuts using a cutoff disc on an angle grinder and making sure to bottom the disc out on a piece of scrap metal. I had much less of a pleasant time using a band saw, using a hack saw, etc.
grip-addict
Re: WTB: ST185 Transmission cooler lines (CLOSED - GOT ONE!)
Postby Tippo » Mon Apr 26, 2021 2:59 pm
I got one - thank you to Tecker. Always nice to visit up there!
Tippo
Return to Parts Wanted
