ST165 power window switch
Postby Maet » Fri Jun 04, 2021 9:05 pm
Has anyone ever found a replacement for the driver side window switch?
tinified (1).zip
(715.92 KiB) Downloaded 8 times
Maet
Re: ST165 power window switch
Postby RedCelicaTRD » Fri Jun 04, 2021 10:02 pm
It’s the same switch in a 3rd gen Supra. There are two styles, an early and a late. I believe it was the late that I used which was 90-92 if I remember right. A lot easier to find a switch from a Supra than it is an ST165.
Postby Maet » Fri Jun 04, 2021 10:07 pm
Can you just click in the sideways bar that you press up in order to roll up the window, or is the plastic all one piece?
Maet
Postby RedCelicaTRD » Fri Jun 04, 2021 10:24 pm
One piece. You have to replace the whole switch. Well, you could tear them both apart and replace the little tab but what’s the point.
I replaced mine back in 2007 when I still had an ST165. Now that 3d printing is more widely available maybe someone has made a 3d printed little button.
Postby Maet » Fri Jun 04, 2021 10:52 pm
That's kind of frustrating, not really sure where to look for a complete assembly with that clip intact.
But thanks for the info, it was very helpful
Maet
Postby 93celicaconv » Sun Jun 06, 2021 12:07 am
The good thing in that switch isn't unique to the ST165. All Celica's equipped with power windows (which I think in the USDM, included all GT & GT-S models) had the same switch from 1988-1989. Also all Supras had them from 1989-1993. In fact, there was a very nice 1992 Supra in the salvage yard near me - not sure it is there anymore though. There were also some 88/89 Celica GT's there at one time - not sure if they are there anymore either. If that clip is a weak point on that driver window switch, it could be not many are intact anymore.
93celicaconv
Images: 26
Postby 93celicaconv » Wed Jun 23, 2021 4:14 pm
Maet, did you get your power window switch situation resolved?
I just wanted to let you know that I finally got the chance to visit my local salvage yard this morning. Both the '89 Celica's and the one 1990 Supra that used to be there maybe 4-6 months ago are no longer there. So there is nothing I can help you with on this one.
93celicaconv
Images: 26
Postby Maet » Thu Jun 24, 2021 12:23 am
I haven't messed with it, just been living life on the edge when I reach over on the freeway to roll up the window lol.
It's not on the top of the never ending list for the Celica so I'll get to it eventually. I might need to stop at a salvage yard soon anyway so I'll see if any switchers are there.
Maet
