TWM to 7th gen shifter conversion
Postby Maet » Sat Jun 05, 2021 10:35 pm
I currently have a TWM shifter in my 165 and I've read that you can push the shift rod into your housing and it should work well. My mindset is that a stock Toyota shifter should be more streetable, but is there anything I would need to install it with all the TWM washers/plates that would be in the housing?
Maet
