90 All-Trac Check Engine Light Not Coming On..No Start
• Page 1 of 2 • 1, 2
My check engine light will not come on at any time. With the key in the ON position it should illuminate. The car will crank but not start. It stumbles a little if I crank it with some starter fluid. I swapped in another ECU and the problems persists. I also swapped in EFI and fuel pump relays and still the check engine light will not come on. I am in the process of replacing the fuel pump now but am afraid the car will not start for the same reason that there is no check enging light. So the question here is....
What might be causing the check engine light to not come on when I turn the key to the ON/ACC position?
none
- supra-raleigh
Re: 90 All-Trac Check Enging Light Not Coming On..No Start
Id start by checking for power at the ecu.
93 ST185
90 ST185 gen3
93 SW20 2grfe
89 ST165 2grfe swap in progress
89 SV25 gen4 3sgte
86 AW11 2grfe
86 AE86 1uz vvti
86 MA60 3uz
89 AE95 sedan 3sgte
88 AE95 wagon
17 4runner TRD Off Road
90 ST185 gen3
93 SW20 2grfe
89 SV25 gen4 3sgte
86 AW11 2grfe
86 AE86 1uz vvti
86 MA60 3uz
89 AE95 sedan 3sgte
88 AE95 wagon
- Tecker185
Re: 90 All-Trac Check Engine Light Not Coming On..No Start
Did this situation just happen suddenly for you? Or were there symptoms before it got to where you are now? Or did you buy the car recently with this problem?
The EFI system has a fuse also - may want to check if that fuse is blown.
Do you have the all the service manuals with wiring diagrams?
- 93celicaconv
- Images: 26
The car ran fine for the last time in 2017. It then sat for a year. Then, I tried to start it and it ran poorly and stumbled as if it was starved for fuel. The car sat in the car-port as it does now.
As for the situation I have now with the no check engine light, this just happened when I tried to get the car going yesterday.
I have checked the IG fuses and the EFI fuse and put in a spare EFI relay that, following the Toyota Service Repair Manual for the 1990 All-Trac, proved the relay was OK. I also have the Toyota Electrical Manual for this car.
With the ignition in the ON position, the car has 12V at the fuel pump harness, but I do not hear the pump.
The diagnostic port under the hood gets 12V at the B+ with ignition ON and the Fp slot gets around 10.5V while cranking.
At this time, the simple explanation may be correct;
1. The fuel pump failed after letting the car sit for so long.
2. The light bulb for the CHECK engine light coincedentally has burned out.
I have the fuel tank 1/2 of the way out now. I removed all the 10mm bolts holding the plastic cover for the tank but the cover is bound up on the side right by the filler neck. I think that by removing the 10mm bolt in the wheel well just behind the rear driver side tire will allow me to remove what the TSRM refers to as the fuel inlet pipe protector.
So, the plan is to inspect inside of the tank and get it cleaned up and sealed if neccessary. Then I will install my new Denso fuel pump with stainer. This will likely get the car going.
Then I plan on removing the guage cluster to replace the capacitors on my slow tachometer and also put in a new light bulb for the CHECK engine light.
I'll post back when I get it going but feel free to chime in if you think it may help.
Thanks Guys.
Any tips from here are appreciated. For instance, must the car be raised up to fully remove the fuel tank?
Thanks Guys.
none
- supra-raleigh
Only note I have is that the fuel pump wiring harness should not have 12V with the ignition key in the ON position. This car has a safety feature that does not provide power to the fuel pump unless the ignition is in the start position or the engine is running. So this part, if what you say is true, is a problem in the control circuit somewhere.
I would have brought a temporary separate 12V wire from the battery to the +12V terminal on the fuel pump wiring harness to check for pump operation before going through the difficulty of removing the tank. It's possible your pump is fine.
- 93celicaconv
- Images: 26
Bridging B+ and FP in the diagnostic box is a lot easier.
underscore wrote:Bridging B+ and FP in the diagnostic box is a lot easier.
But not the same. OP said car was sitting for a long time. Possible mice/rats bit through a wire somewhere. Wiring has to be all good to do the B+ & FP jumper. I was looking to bypass all except the fuel pump to see if the pump worked first, then work back (if the OP is right in that the fuel pump doesn't work when trying to start the car).
- 93celicaconv
- Images: 26
That's a very good point, though I'd still try the jumper first since it's so easy.
Also maybe a dumb question, but it does have gas in the tank right?
- Roreri
93celicaconv wrote:Only note I have is that the fuel pump wiring harness should not have 12V with the ignition key in the ON position. This car has a safety feature that does not provide power to the fuel pump unless the ignition is in the start position or the engine is running. So this part, if what you say is true, is a problem in the control circuit somewhere.
93celicaconv is right about there is not supposed to be 12V at the fuel pump with the key in the ON postion. I had a jumper bridging the B+ to Fp so that is why there was 12V at the pump harness. Upon removing the jumper, there is no voltage which is normal.
I have since run wires directly from the battery to the fuel pump plug and the pump still does not move or make a sound.
There is about 3 gallons of fuel in the tank. I am going to syphon that out and then proceed to removing the tank. I am going back out to the car right now---about 9am here in San Antonio. I really have to get this car going before we start work on a retaining wall at 6pm tonight. The car is now sitting in what will be workspace.
Next task is to remove the Fuel Tank Protector(FTP) but first I am TRYING to remove the Fuel Inlet Pipe Protector (FIPP). I am stuck here at the FIPP.
I will report back soon.
none
- supra-raleigh
Here is a top tip for removing the Fuel Inlet Pump Protector;
Remove the 2nd of two bolts BEFORE you try to wrestle it free from the wheel well. The 2nd bolt is located relative to the rim/tire at the 1 o'clock position and couple of inches down.
none
- supra-raleigh
Update.
The tank is off. Another tip; DO NOT try to use the SAE equivalent flare wrench for the fuel tank line. I tried with an SAE flare wrench and felt it slip slightly. I immediately stopped. As stated by alltrac.net user tw2, use a 14mm flare wrench. I just bought one from AutoZone for $8.99.
none
- supra-raleigh
Update. The tank is being rinsed with soapy water. I will do this until there is zero debris in the rinse water. Then, I will do a final rinse to remove the soap suds, drain it, and use a liberal amount of WD-40 to prevent flash rust inside the tank.
none
- supra-raleigh
After hours of rinsing, the water rinsing the fuel tank is now clear of debris. I am going to leave it full of water overnight then rinse some more tomorrow and then do the WD-40 step.
none
- supra-raleigh
And, to answer one of my questions, the car does not need to be raised at all to remove the fuel tank. However, I would raise the car up if I had to do it again.
none
- supra-raleigh
