Quarter Window Moulding/Trim Clips ST165
Postby teal1 » Tue Aug 09, 2022 6:37 pm
If you've had the misfortune to remove/re-install the trim/moulding attachments clips, you'll know what I'm referring to.
On the bottom of the glass to which the trim/moulding clips are several piecesno longer carried by Toyota:
52767-20020
These are brittle little plastic parts that are typically broken when the trim is removed for painting.
If any of you parts hoarders out there have them, I'd be delighted and grateful to purchase from you.
Many thanks.
teal1
